Tools
Error when generating TCP traffic in WAN Killer: Connection is forcefully rejected
This article provides brief information and a resolution to the following error while generating TCP traffic in WAN Killer. Connection is forcefully rejected
10/12/2018 6:19 PM
3/14/2019 8:44 PM
Engineers Toolset
The error is due to security issues.
  1. Install Simple TCP/IP services.
    Note: By default, Windows does not have this installed and you can install it from Add/Remove Windows Components.
  2. Configure the switch/router to accept the traffic using the following command:
    service tcp-small-servers
