Error when editing the custom property values for a node
This article addresses an error that displays in the Orion Web Console when you edit the custom property values for a node. Error: SysWebFroms.PageRequestManagerServerErrorExceptionSys.WebForms.PageRequestManagerServerErrorException: The MaximumValue property of 'RangeValidatorStatisticsPollInterval' cannot be converted to type 'Integer'.
11/8/2018 4:47 PM
11/8/2018 4:47 PM
When you edit the custom property values for a node and click Test, the Orion Web Console generates the following error:
Network Performance Monitor
The selected node is a VMware ESX® server polled by VMware vCenter®. When you click Test in Edit Nodes, the Orion Web Console generates an exception error because the selected node exists in the VIM_Hosts table and not the Nodes table.
When you edit a node, click Test only for valid nodes. Do not click Test for VMware ESX nodes polled by VMware vCenter, which are not managed as a node in Orion NPM.
