Error when downloading configs from F5 devices in NCM
Failed to download F5 config backups: Syntax Error: An unexpected argument "tmsh" can be seen in the session trace, or if one would log in to the devices.
When you download a configuration from an F5 device, NCM tries to send Traffic Management Shell (TMSH) commands. If the user assigned to the device does not have rights to issue the command from a Traffic Management Operating System (TMOS) level, the login validation may pass, but the download will fail.
The following error cam be seen in the session traces:
Also, if you log in to the command line interface (CLI) on the device with the same credentials from an SSH or Telnet client (such as PuTTY or Secure CRT) and issue a TMSH command like
tmsh show /system version
a similar error displays.
Provide the F5 user an administrator role to switch the bash and issue the command.
- From the Web Console, go to settings > NCM settings > Device Templates and look for the the f5 BIG IP Device template.
- Turn the Use for Auto Detect to Off.
- Edit the Device Template(this will force a copy).
- Rename the copy then set the Use for auto-detect to Yes.
Modify the following command:
<Command Name="RESET" Value=""/>
Use the same line and add run /util bash:
<Command Name="RESET" Value="run /util bash" RegEx="#"/>
The RegEx=''#'' was added at the end of the command since the prompt will change from (TMOS)# to maybe (standby)~#. This will tell NCM to accept the # as the prompt regardless of what precedes it.
Note: According to F5 article K10272, remote users attempting to run this command that do not have advanced shell privileges see the following error:
Syntax Error: "bash" unexpected argument"
