Error when adding nodes to VNQM: Node is not IP SLA capable
The following message is displayed when adding nodes to VNQM: Node is not IP SLA capable.
10/26/2018 7:11 PM
10/26/2018 7:11 PM
VoIP & Network Quality Manager
This error can be caused by any of the following:
  • The node fails the IP SLA capability test. VNQM polls this OID to determine if the node is IP SLA-capable 1.3.6.1.4.1.9.9.42.1.1.1.0. If this OID is not present on the device the node is determined to be "not IP SLA capable" and will not be added.
  • Adding a node to an additional polling engine where VNQM is not installed.
Use the SolarWinds SNMP Walk Tool to verify that the required OID is present on the device.
Adding a node where VNQM is not installed
Adapt the steps in the following procedure to install VNQM on the additional polling engine:
Install or upgrade an additional poller
