Tools
Error message: "Database is nearing its maximum capacity" while you are using Engineer's Toolset Network Performance Monitor
The Engineer's Toolset edition of Network Performance Monitor uses a Microsoft Access database. Access databases have an inherent file size limit of 2GB. Once your database reaches this size, the Network Performance Monitor will no longer be able to store statistics. This article describes how to work around this size limit. ETS NPM.
10/10/2018 5:35 PM
12/21/2022 3:13 PM
If you are monitoring a large network or storing data over an extended period of time, you should consider using  Network Performance Monitor which uses a Microsoft SQL Server database.
To continue using the Engineer's Toolset edition of Network Performance Monitor, you will want to shrink the database periodically.
A possible error message as below might show up.
Engineers Toolset
This error occurs due to the database nearing its 2 Gigabyte size limit.
Solution 1:
  1. Close Network Performance Monitor.
  2. Run the following executable:
C:\Program Files (x86)\SolarWinds\Toolset\Database-Maint.exe
  3.  Select Compact and Repair and click Run Job.
  4.  Select Network Performance Monitor - Nightly Maintenance and click Run Job.
  5.  Open Network Performance Monitor.
Solution 2:
  2. Open Microsoft Access (2000 or later).
  3. Select Tools > Database Utilities > Compact and Repair Database.
  4. Select the following file:
C:\ProgramData\SolarWinds\Toolset\SWNetPerfMon.cfg
  1. Once the repair has completed, close Access.
  2. Open Network Performance Monitor.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
