Security Compliance
Error codes and patches for WSUS servers
This article describes the error codes and patches that apply to WSUS servers.
Patches and KBs
| KB | TARGET VERSION | DESCRIPTION |
WSUS 3.0 Service Pack 2 | 3.0 SP2 |
An update for Windows Server Update Services 3.0 Service Pack 2 is available (KB2734608)
KB2734608 updates the hashing algorithm and calculations of the content hashes stored in the update metadata. The 0x80246003 error displayed in Windows 8 and Windows Server 2012 server systems is caused by the WUAgent not being able to validate the newer hashing algorithm because the update only has the older hashes.
When a WSUS 6 server synchronizes from a WSUS 3 server without KB2734608, the WSUS 3 server doesn’t have the new hash calculations. As a result, the WSUS 6 server cannot get them from the synchronized metadata. Updating a Windows 8 or Windows Server 2012 client from the WSUS 6 server will fail, just as it would from the unpatched WSUS 3 server. |
WSUS 3.0 Service Pack 2 | 3.0 SP2 | An update for Windows Server Update Services 3.0 Service Pack 2 is available. (© 2017 Microsoft, available at https://support.microsoft.com/, obtained on January 24, 2016.) This update improves the WSUS communication channels (just 1024bit+ certs can be used) . This includes trusting only files that are issued by the Microsoft Update certification authority. |
Error codes
- Windows Update Agent Result Codes (© 2017 Microsoft Corporation, available at https://technet.microsoft.com, obtained on January 24, 2017)
- Understanding Windows Update Error Codes
