Error When Launching or Logging into Network Atlas
This article provides step by step guide in resolving errors related to launching or logging into Network Atlas on your Additional Polling Engine or Additional Workstation.
10/30/2018 11:14 PM
2/10/2022 8:13 PM
Errors related to launching or logging into Network Atlas on your Additional Polling Engine or Additional Workstation. An unexpected error occurred while trying to connect to the server. Please contact support. ERROR Solarwinds.InformationService.Contract2.InfoServiceProxy - an error occurred opening a connection to the Orion communication service.
Related Errors:
from NetworkAtlas.log
Orion Platform
Version Installed on APE or Additional Workstation does not match the one installed on the Primary Polling Engine
1. Check Network Atlas Version on Primary Polling Engine
    Example Versions: 1.12.0.1007, 1.8.330.1 etc.
NOTE: Versions used on both machines should match C:\ProgramData\Solarwinds\Installers
2a. Copy Network Atlas MSI installer to APE or Additional Workstation
2b. Download Network Atlas from the Orion Web Console or Customer Portal
  • If you edit a current map on any view and enable the Show Network Atlas Download link
  • Login and Download Network Atlas from Customer Portal
3. Uninstall the incompatible version of Network Atlas
4. Install a compatible version of Network Atlas
