Tools
Error 'There seems to be a problem with the microsoft data access components (MDAC) installed on this machine.' when accessing an Engineer's Toolset Desktop tool
This article shows how to troubleshoot a problem where any Engineer's Toolset Desktop tool that uses an Access Database does not launch with a Microsoft Data Access Components (MDAC) error
Most of the Engineer's Toolset Desktop tools uses an older version of Microsoft Access as the database. When MDAC or certain Microsoft components are removed, some Engineer's Toolset Desktop tool will not launch completely and show an error similar below.
There seems to be a problem with the microsoft data access components (MDAC) installed on this machine. This SolarWinds tool requires MDAC.
MDAC 2.8 is required, and it should be installed with Windows Server 2003. It is possible, however, that an older version of MDAC remains after upgrading your operating system from a previous version.
Download and install the Component Checker too l (© 2020 Microsoft, available at https://www.microsoft.com/en-us/, obtained on June 21, 2020). To confirm your MDAC version, use Microsoft's Component Checker tool, as follows:
- Run the Component Checker, as instructed on the page linked above, and then check the MDAC version.
- Note: On Windows Server 2003, MDAC version 2.8 should be installed. For more information, see the MSDN Blog article, "MDAC Install Issues - Excellent Overview" (© 2020 Microsoft, available at https://www.microsoft.com/en-us/, obtained on June 21, 2020).
- If the installed version of MDAC is older than version 2.8, download a new version of MDAC from Microsoft (© 2020 Microsoft, available at https://www.microsoft.com/en-us/, obtained on June 21, 2020).
- If the installed version of MDAC is version 2.8 or higher, an incompatible .dll may be installed. To address this condition, reinstall MDAC, as indicated above.
- After you have confirmed that a valid version of MDAC is installed, run the SolarWinds Configuration Wizard again, opting to confirm all settings (Website, Database and Services).
If the steps above does not work, the end-user should reach out to their systems administrator or Microsoft support to have MDAC properly added back in the machine.
Disclaimer: The content posted herein are provided as a suggestion or recommendation to you for your internal use. The information set forth herein may come from third party website or customers. SolarWinds is not liable for any downtime or any issue that may occur if you perform the following suggestions on the link provided. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.
