Tools
Error: Home directory does not exist when logging in to Serv-U web client
This article describes the issue when you receive the Home directory does not exist error message.
- Serv-U service account does not have permission to access the home directory
- The home directory path does not exist
1. To resolve this issue, see Configure Serv-U and FTP Voyager Scheduler to access network files or folders
2. Use local home directory.
3. Another possible cause is Windows and LDAP authentication is running at the same time. Please make sure that only one method is active to prevent this issue.
4. Make sure that the actual directory path does exist on the location. You can verify it by going to the home directory path from the Serv-U server.
