Error: Connection to NTA Flow Storage Database has been lost. NTA cannot save any flows now
The following error appears in NTA: Connection to NTA Flow Storage Database has been lost. NTA cannot save any flows now.
11/29/2018 10:47 PM
5/11/2026 9:37 PM
The connection to NTA Flow Storage Database has been lost. NTA cannot save any flows now.
Possible Errors:
INFO  FastbitCLR.Disk.VolumeFs - File 'C:\ProgramData\SolarWinds\NTA\FlowStorage\Data\Flows\_toBeDeleted\e3f78e64558747e7822a06fe63c22474' opened and marked for delete. Handle error code was '2'.
WARN  FastbitCLR.Disk.VolumeFs - File [C:\ProgramData\SolarWinds\NTA\FlowStorage\Data\Flows\_toBeDeleted\fc091fe2aee142869c0fe62d063b5e00] was marked for delete but failed to delete immediately, error code [5].
Netflow Traffic Analyzer
This issue occurs when NTA Flow Storage is about to reach full capacity or when an Antivirus application is scanning the flow storage folder and temp directory.
RESOLUTION 1:
  1. Check that the flow storage directory on the flow storage server has enough space.
  2. Verify that the built-in Network Service Account has read and write access to the location of the NTA Flow Storage Database.
  3. Check if any antivirus application is turned on and actively scanning flow storage directories.
  4. Verify the directories that need to be excluded from antivirus protection. Refer to Files and directories to exclude from antivirus scanning for Orion Platform products
  5. Run NTA storage Configurator on the Orion NTA storage server.
NOTE: Make sure the SQL information, User ID, and Password are correct
1. Rerun the CW and for SQL Server config (both for SolarWinds Platform DB and NTA Flow Storage) in the server field add/make sure there is "TCP:" before the server hostname/IP. Let us know if the issues remain.
for example: "ourserver1" will be changed to "TCP:ourserver1"
 For additional information, see:
