Error: Another website may be using the same port
This article describes the issue when you receive the following error message: The configuration wizard has failed
The configuration wizard has failed.
This issue occurs when similar port numbers are assigned to Websites in IIS manager.
- Start > Run > Inetmgr and launch the IIS manager.
- In IIS manager, check all the sites bindings by doing the following:
a. Open IIS and expand the Websites list.
b. Right-click on a website.
c. Select Bindings.
d. Go through each website listed and make sure there is no similar ports assigned to more than one website.
For reference: https://support.microsoft.com/en-us/kb/149605 (© 2018 Microsoft Corporation, available at https://support.microsoft.com/en-us, obtained on 2018).
