Tools
Engineer's Toolset for desktop device limitations
Device limit of engineers toolset. Some users may find they reached a limit of devices that can be added to the application. The desktop version of the Engineer's ToolSet does not have a fixed limit of the number of devices that can be monitored. However, the system uses an MS Access database and this has a limit of 2 GB.
The desktop version of the Engineer's Toolset does not have a fixed limit of the number of devices that can be monitored. However, the system uses an MS Access database and this has a limit of 2 GB.
The effect of this is that the system does limit the total number of device, interface and volumes that can be added due to the size limit mentioned above.
