Enable multicast monitoring in NPM
How do I monitor Multicast routing in NPM? Make sure that Multicast Routing is enabled in the node resources.
To monitor Multicast routing in NPM, enable polling for Multicast Routing in the node resources. The node should support this feature in order for it to appear in the resources.
Multicast is a routing protocol. To enable it:
- In the Orion Web Console, click Settings > Manage Nodes.
- Select the node and click List Resources.
- On List Resources, make sure Multicast Routing is selected.
