Enable monitoring on unmonitored traffic in NTA
This article describes how to monitor unmonitored traffic in NTA. Enable monitoring. NetFlow Traffic Analyzer.
- Go to Settings > NTA Settings > Application and Service Ports.
- Enable all monitoring. Note: If an application is disabled for monitoring, then it cannot be monitored.
- By default, only ports under 1023 are selected in NetFlow.The Unmonitored Traffic (-1) that is showing in your NTA is traffic where the application has not been defined on the port.
- If there are still ports showing as Unmonitored Traffic, check your disabled applications.
