Tools
Enable debug mode
This article provides information on enabling the debug mode to do advanced logging if there are some issues that need in-depth investigation such as performance and product errors.
- Right click the tray icon and select Stop Serv-U to shut down any running Serv-U processes.
- Right click the tray icon and uncheck the box labeled "Start Serv-U as Service".
- Run Serv-U in debug mode from the terminal:
a. Open the terminal.
b. Go to the directory where Serv-U is installed using the CD command. For example: CD C:\Program Files\RhinoSoft\Serv-U
c. Run Serv-U using the following command:Serv-U.exe –debug -socketlogging
- Right click the tray icon and select Start Management Console.
- In the Management Console, go to Domain Activity > Settings and turn on all commands for logging (all boxes should be selected).
- Repeat the test.
- Restart Serv-U:
a. Right click the tray icon and select Stop Serv-U to shut down any running Serv-U processes.
b. Right click the tray icon and check the box labeled "Start Serv-U as Service" to run Serv-U as service.
c. Right click the tray icon and select Start Serv-U to run the application.
The debug logs will be found in ProgramData\Rhinosoft\Serv-U\DebugLogs\Domain_Name-WorkerThreadLog.txt.
It is important to restart Serv-U after the test.
For more information on enabling logging reference, see the Setting Up Serv-U's Log article.
