Database Management
Enable SSL for DPA (with custom certificate)
SSL encryption protects sensitive information that is passed over the network. This type of encryption may not be necessary in many environments and slows down the web server since all information (including graphics) must be encrypted.
SolarWinds allows you to configure custom certificates. However, SolarWinds Support does not provide configuration assistance. If you need assistance, please contact the vendor who provided your certificate.
Note: In DPA 9.2 and later, SSL is configured automatically, and by default uses port 8124.
These instructions use a Java Development Kit to generate a key for your server. To install an commercial key, see the advanced setup section at the end of this document.
Task 1: Find or install the keytool utility
The keytool utility is often installed on a server since it is part of the Java Development Kit. If it does not exist, you must install it.
Linux
SolarWinds DPA ships a JRE for Linux as part of the product and the keytool utility can be found in the following directory:
<installDirectory>/iwc/jre_linux/bin
Windows
SolarWinds DPA ships a JRE as part of the product and the keytool utility can be found in:
C:\Program Files\SolarWinds\DPA\iwc\jre\bin
Other OS
If you are not using Windows or Linux for your DPA server, a JRE/JDK must be installed separately. The installation will include the keytool utility.
Task 2: Generate a server key using the keytool utility
Run the following command from <installDirectory>/iwc/tomcat/conf:
<keytool directory>/keytool -genkey -alias tomcat -keyalg RSA -validity 365 -keystore ./.keystore
You are prompted for two passwords. Specify "changeit" for both passwords. When asked for your first and last name, put in the name of the server instead. The server name must match the name that the user will specify in the URL. The remaining information should be answered with your own information.
Task 3: Change the server.xml file
Change the port on the SSL connectors from 8123 to 8124. The SSL connector is identified by the SSLEnabled="true" attribute. The other connector is an HTTP connector and port and must remain 8123.
Open the file <installDirectory>/iwc/tomcat/conf/server.xml and make sure the SSL connector is present within the {Service} tag. The following is an example of a server.xml file setup for SSL.
<Connector port="8124" maxHttpHeaderSize="20480" URIEncoding="UTF-8" scheme="https" secure="true" SSLEnabled="true" clientAuth="false" useServerCipherSuitesOrder="true" compression="on" compressionMinSize="2048" compressableMimeType="text/html,text/xml,text/csv,text/css,text/javascript" keystoreFile="conf/.keystore" sslEnabledProtocols="TLSv1.1+TLSv1.2+TLSv1.3" ciphers="ALL:!aNULL:!ADH:!eNULL:!LOW:!EXP:!DES:!3DES: !TLS_DHE_RSA_WITH_AES_128_CBC_SHA:!TLS_DHE_RSA_WITH_AES_128_CBC_SHA256: TLS_DHE_RSA_WITH_AES_128_GCM_SHA256:!TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA:RC4+RSA:+HIGH:+MEDIUM"/>
AIX Note: For AIX uncomment the following entry instead:
<Connector port="8124" maxHttpHeaderSize="20480" URIEncoding="UTF-8" scheme="https" secure="true" SSLEnabled="true" clientAuth="false" useServerCipherSuitesOrder="true" compression="on" compressionMinSize="2048" compressableMimeType="text/html,text/xml,text/csv,text/css,text/javascript" keystoreFile="conf/.keystore" sslEnabledProtocols="TLSv1.1+TLSv1.2+TLSv1.3" ciphers="ALL:!aNULL:!ADH:!eNULL:!LOW:!EXP:!DES:!3DES: !TLS_DHE_RSA_WITH_AES_128_CBC_SHA:!TLS_DHE_RSA_WITH_AES_128_CBC_SHA256: !TLS_DHE_RSA_WITH_AES_128_GCM_SHA256:!TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA:RC4+RSA:+HIGH:+MEDIUM" algorithm="ibmX509"/>
Task 4: Start DPA and view results
- Start the DPA server (startup.sh or start the service on Windows).
- Users should begin using https://<hostname or IP>:8124 to connect to the DPA user interface.
If the link does not work, check <iwc_dir>/iwc/tomcat/logs.
Advanced SSL setup
DPA uses Tomcat as the web server. For advanced instructions on using SSL with Tomcat, please use the following link:
http://tomcat.apache.org/tomcat-8.0-doc/ssl-howto.html
Use a custom certificate
By default, DPA 9.2 and later automatically generates a self-signed certificate that is used for secure communication over HTTPS. The following article describes how to replace the self-signed certificate with a custom certificate:
