Enable SNMP access and trap forwarding for AIX
This article describes how to enable SNMP access and trap forwarding on AIX. SNMP access and trap forwarding enable SNMP-based managers to poll the managed system and receive its alerts. If System Health Monitoring is also installed on the managed system, hardware alerts can be forwarded as SNMP traps.
- With root authority, open the /etc/snmpdv3.conf file in a text editor.
- Create a community entry for the customized access view. You can create a new community entry or reuse the default community entry. For example:
# communityName securityName securityLevel netAddr netMask storageType COMMUNITY myDirector myDirector noAuthNoPriv 0.0.0.0 0.0.0.0 -
- Define a security group that includes the community you defined. You can create a new group entry or reuse the default group entry. For example:
# groupName securityModel securityName storageType VACM_GROUP mygroup_v1 SNMPv1 myDirector – VACM_GROUP mygroup_v2c SNMPv2c myDirector -
Note: The security group name cannot begin with director_group.
- Define a view entry to include or exclude MIB objects. For example:
# viewName viewSubtree viewMask viewType storageType VACM_VIEW director_View internet - included - VACM_VIEW director_View 1.3.6.1.4.1.2.2.1.1.1.0 - included - VACM_VIEW director_View 1.3.6.1.4.1.2.6.191.1.6 - included - VACM_VIEW director_View 1.3.6.1.4.1.2.6.159 - included - # exclude snmpv3 related MIBs from the view VACM_VIEW director_View snmpModules - excluded - VACM_VIEW director_View 1.3.6.1.6.3.1.1.4 - included - VACM_VIEW director_View 1.3.6.1.6.3.1.1.5 - included - # exclude aixmibd managed MIBs from the view VACM_VIEW director_View 1.3.6.1.4.1.2.6.191 - excluded -
- Create an access entry to authorize the security group to the customized access view. For example: #
groupName securityLevel securityModel readView notifyView VACM_ACCESS mygroup_v1 - - noAuthNoPriv SNMPv1 director_View - director_View - VACM_ACCESS mygroup_v2c - - noAuthNoPriv SNMPv2c director_View - director_View -
- To configure SNMP traps, perform steps 7 and 8. Otherwise, go to step 9.
- Specify a target address value for each destination to which the IBM Director will send SNMP traps. For example:
# targetAddrName tDomain tAddress tagList targetParams TARGET_ADDRESS Target1 UDP 9.181.65.131 traptag trapparms1 - - -
- Specify a trap community value. For example:
# paramsName mpModel securityModel securityName securityLevel storageType TARGET_PARAMETERS trapparms1 SNMPv1 SNMPv1 myDirector noAuthNoPriv -
- Save and close the /etc/snmpdv3.conf file.
- Stop and restart the cimlistener daemon by typing the following commands and pressing Enter after each:
/opt/freeware/cimom/pegasus/bin/cimlistener -s /opt/freeware/cimom/pegasus/bin/cimlistener
- Stop and restart the IBM Director AgentX subagent by typing the following commands and pressing Enter after each:
/opt/ibm/icc/cimom/bin/icesnmp stop /opt/ibm/icc/cimom/bin/icesnmp start
Additional Resources:
