Enable NetFlow on Cisco VLAN interfaces to show layer 2 and layer 3 traffic
This article discusses how user can enable Netflow on the VLAN interface to both layer 2 and 3 traffic.
Note: If these commands do not work for your Router or Switch please refer to your specific make and model to find the relevant commands.
To see the traffic arriving on the switch ports that belong to VLAN, you need to enable layer 3 NetFlow to display the information on the VLAN interface.
| LAYER 3 SWITCHED NETFLOW COMMANDS | |
ip flow ingress | Enables Netflow on the layer 3 interface. |
ip flow ingresslayer2-switched | Enables layer 3 switched Netflow. |
ip flow ingress infer-fields | Capture the input and output interfaces for logical interfaces. |
- Applying these commands on the device may differ and many devices only support NetFlow layer 3 but not layer 2.
- Make sure that the NDE version is v5. By default, it is set on version 7.
- For more information on NetFlow Layer 3, see the Cisco documentation (© 2018 Cisco, available at https://www.cisco.com, obtained on April 3, 2018).
The key command to monitor layer 2 is:
ip flow ingress layer2-switched vlan xxxx
| LAYER 2 SWITCHED TRAFFIC COMMANDS | |
ip flow ingress layer2-switched vlan | vlanlist |
ip flow export layer2-switched vlan | vlanlist |
set mls bridged-flow-statistics enable | vlanlist (for CatOS) |
A PFC3B or PFC3BXL running 12.2(18)SXE or higher is required for this command, which enables NDE for all traffic within the specified VLANs rather than just inter-VLAN traffic.
