Tools
Enable HTTPS in Web Help Desk
This article describes how to enable HTTPS in Web Help Desk.
This article describes how to enable HTTPS in Web Help Desk based on your Web Help Desk version.
When a web browser submits an HTTPS request to Web Help Desk, the SSL protocol requires Web Help Desk to respond with a certificate to prove the authenticity of the server. To enable HTTPS, see the appropriate procedure based on your version.
Web Help Desk 12.5 and earlier
See Enable HTTPS in the Web Help Desk Administrator Guide.
This section describes how to enable HTTPS in Web Help Desk by editing the whd.conf file located in the Web Help Desk directory.
You can access the directory from the following locations:
- Microsoft® Windows Server®:
\Program Files\WebHelpDesk - macOS:
/Library/WebHelpDesk - Linux:
/usr/local/webhelpdesk
Web Help Desk 12.5.1 and later
See Configure the server options in the Web Help Desk Administrator Guide.
This section describes how to enable HTTPS by configuring the server options located at Setup > General.
