Tools
ERROR: Too many sessions in Serv-U
This article will provide information on which Limits & Settings to check when a user encountered error when logging in Serv-U that says ERROR: Too many sessions.
- Access Serv-U Management Console.
- Navigate to the Limits & Settings in Domain/Global Level.
- Go to the Limit type under the Connection limits.
- Check if there are limits configured in the following options.
- Maximum number of sessions on server
- Maximum number of sessions per user account
- Adjust or remove the limitations.
