Downloading configuration using SNMP
Information on NCM and downloading or uploading configurations via SNMP.
10/9/2018 2:05 PM
10/9/2018 2:05 PM
Network Configuration Manager
NA
  • NCM will only work on Cisco devices that support the Cisco Config Copy Mib which requires Read/Write issue the SNMP Set.
  • Cannot download configs from devices via SNMP Read only.
  • When using SNMPV3 in Orion for the node, be sure to add the Cisco view to the devices SNMP V3 configuration
  • NCM will only use the SNMP Set for TFTP.
  • See Cisco Documentation (© 2016 Cisco, available at www.cisco.com obtained on August 26, 2016.)  on SNMP Requirements for more information.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
