DownloadConfig and DownloadConfigIndirect commands in NCM
This article explains the presence of the DownloadConfigIndirect command in many of the device templates.
DownloadConfigIndirect command in many of the device templates.Product section
Normal Telnet and SSH downloads use the DownloadConfig command. If a device is set to download to a TFTP or SCP server in the device connection profile, then the command DownloadConfigInDirect is be used.
