Download configs through a script for specific requirements
This article describes a script that can do the following command: copy running-config tftp://iptomytftpserver/config/nameofthedevice (Tftp server is not SolarWinds) This can be done all at once instead of doing this on each device.
This article describes a script that can do the following command:copy running-config tftp://iptomytftpserver/config/nameofthedevice (Tftp server is not SolarWinds)
