Display the latency detail in Orion Web Console
This article describe the steps to add the latency resource within Orion web console.
10/10/2018 3:55 PM
10/10/2018 3:55 PM
This article describes the steps on how to display or view the latency resource within the Orion Web Console.
Orion Platform
  1. Drill down to Node Details page > Click Customize Page (+ sign).
  2. In the search bar, type in Latency then Select any latency resource available.
    For example, select the resource name 'Latency for Today'.
  3. This should display the latency for that node.
