Applications Systems
Display VMware Alarm Context in VMAN Alert Notifications Using Custom SWQL Variables
Display VMware Alarm Context in VMAN Alert Notifications messages or alert mails using custom SWQL variables
When a VMAN alert is triggered by a VMware alarm from vCenter, the alert notification may not include the related virtual infrastructure names by default. You can use custom SWQL variables in the alert action to display the vCenter, ESXi host, cluster, datastore, datacenter, and virtual machine associated with the triggered alarm.
The values are retrieved from Orion.VIM.TriggeredAlarmState and the related VMAN entities.
1. Validate the alarm relationships in SWQL Studio
Run the following query to check which relationship IDs are populated for recent triggered alarms:
SELECT
tas.DisplayName AS AlarmName,
tas.Timestamp,
vc.Name AS VCenterName,
vm.Name AS VMName,
h.HostName AS ESXiHost,
cl.Name AS ClusterName,
dc.Name AS DataCenter,
ds.Name AS DatastoreName
FROM Orion.VIM.TriggeredAlarmState tas
LEFT JOIN Orion.VIM.VCenters vc
ON vc.VCenterID = tas.RelatedVCenter
LEFT JOIN Orion.VIM.VirtualMachines vm
ON vm.VirtualMachineID = tas.RelatedVirtualMachine
LEFT JOIN Orion.VIM.Hosts h
ON h.HostID = vm.HostID
LEFT JOIN Orion.VIM.Clusters cl
ON cl.ClusterID = h.ClusterID
LEFT JOIN Orion.VIM.DataCenters dc
ON dc.DataCenterID = h.DataCenterID
LEFT JOIN Orion.VIM.DataStores ds
ON ds.DataStoreID = tas.RelatedDatastore
2. Alert Definition
In your alert definition under triggered action section use the below alert variables (either in Alert Message or Email Body)
VM: ${N=SWQL;M=SELECT TOP 1 ISNULL(vm.Name,'') AS VMName FROM Orion.AlertObjects ao JOIN Orion.VIM.TriggeredAlarmState tas ON tas.Uri=ao.EntityUri LEFT JOIN Orion.VIM.VirtualMachines vm ON vm.VirtualMachineID=tas.RelatedVirtualMachine WHERE ao.AlertObjectID=${N=Alerting;M=AlertObjectID}}
ESXi Host: ${N=SWQL;M=SELECT TOP 1 ISNULL(h.HostName,'') AS ESXiHost FROM Orion.AlertObjects ao JOIN Orion.VIM.TriggeredAlarmState tas ON tas.Uri=ao.EntityUri LEFT JOIN Orion.VIM.VirtualMachines vm ON vm.VirtualMachineID=tas.RelatedVirtualMachine LEFT JOIN Orion.VIM.Hosts h ON h.HostID=vm.HostID WHERE ao.AlertObjectID=${N=Alerting;M=AlertObjectID}}
Cluster: ${N=SWQL;M=SELECT TOP 1 ISNULL(cl.Name,'') AS ClusterName FROM Orion.AlertObjects ao JOIN Orion.VIM.TriggeredAlarmState tas ON tas.Uri=ao.EntityUri LEFT JOIN Orion.VIM.VirtualMachines vm ON vm.VirtualMachineID=tas.RelatedVirtualMachine LEFT JOIN Orion.VIM.Hosts h ON h.HostID=vm.HostID LEFT JOIN Orion.VIM.Clusters cl ON cl.ClusterID=h.ClusterID WHERE ao.AlertObjectID=${N=Alerting;M=AlertObjectID}}
Datacenter: ${N=SWQL;M=SELECT TOP 1 ISNULL(dc.Name,'') AS DataCenterName FROM Orion.AlertObjects ao JOIN Orion.VIM.TriggeredAlarmState tas ON tas.Uri=ao.EntityUri LEFT JOIN Orion.VIM.VirtualMachines vm ON vm.VirtualMachineID=tas.RelatedVirtualMachine LEFT JOIN Orion.VIM.Hosts h ON h.HostID=vm.HostID LEFT JOIN Orion.VIM.DataCenters dc ON dc.DataCenterID=h.DataCenterID WHERE ao.AlertObjectID=${N=Alerting;M=AlertObjectID}}
vCenter: ${N=SWQL;M=SELECT TOP 1 ISNULL(vc.Name,'') AS VCenterName FROM Orion.AlertObjects ao JOIN Orion.VIM.TriggeredAlarmState tas ON tas.Uri=ao.EntityUri LEFT JOIN Orion.VIM.VCenters vc ON vc.VCenterID=tas.RelatedVCenter WHERE ao.AlertObjectID=${N=Alerting;M=AlertObjectID}}
Datastore: ${N=SWQL;M=SELECT TOP 1 ISNULL(ds.Name,'') AS DatastoreName FROM Orion.AlertObjects ao JOIN Orion.VIM.TriggeredAlarmState tas ON tas.Uri=ao.EntityUri LEFT JOIN Orion.VIM.DataStores ds ON ds.DataStoreID=tas.RelatedDatastore WHERE ao.AlertObjectID=${N=Alerting;M=AlertObjectID}}
