Discovery import fails on SAM+VMAN Free polling Engine
Error during import. Check running services and try import again. There was an error processing the request. Free poller import fails.
- Add SAM node-based license
- Install free polling engine
- Check that there is Configuration = FREE (under Solarwinds/Core) present in registry on free polling engine
- Run discovery
- Discovery import fails with error present on UI
- Error in OrionWeb.log
You may also check the log file: C:\ProgramData\SolarWinds\Logs\Orion\Core.BusinessLayer.log
ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.APM.BlackBox.Wstm.Common.Models.Discovery.DiscoveryPluginResult,SolarWinds.APM.BlackBox.Wstm.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.Interfaces.SNMP.Common.Models.Discovery.InterfacesSnmpDiscoveryPluginResult,SolarWinds.Interfaces.SNMP.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.Interfaces.Common.Models.Discovery.InterfacesDiscoveryPluginResult,SolarWinds.Interfaces.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.Interfaces.Import.Common.Models.Discovery.InterfacesImportDiscoveryPluginResult,SolarWinds.Interfaces.Import.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.Interfaces.WMI.Common.Models.Discovery.InterfacesWmiDiscoveryPluginResult,SolarWinds.Interfaces.WMI.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.Wireless.Common.Models.Discovery.WirelessDiscoveryPluginResult,SolarWinds.Wireless.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.Nexus.Common.Models.NexusDiscoveryPluginResult,SolarWinds.Nexus.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.Wireless.Heatmaps.Common.Models.Discovery.WLHMDiscoveryPluginResult,SolarWinds.Wireless.Heatmaps.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.APM.BlackBox.Sql.Common.Models.Discovery.ApmBlackBoxSqlDiscoveryPluginResult,SolarWinds.APM.BlackBox.Sql.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.APM.BlackBox.Exchg.Common.Models.Discovery.ExchangeDiscoveryResult,SolarWinds.APM.BlackBox.Exchg.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.Orion.NetMan.Firewalls.Common.Models.Discovery.AsaDiscoveryPluginResult,SolarWinds.Orion.NetMan.Firewalls.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.APM.BlackBox.ActiveDirectory.Common.Models.Discovery.ActiveDirectoryDiscoveryPluginResult,SolarWinds.APM.BlackBox.ActiveDirectory.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.APM.BlackBox.IIS.Common.Models.Discovery.IISDiscoveryPluginResult,SolarWinds.APM.BlackBox.IIS.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type SolarWinds.DeviceStudio.Common.Models.Discovery.DeviceStudioDiscoveryPluginResult,SolarWinds.DeviceStudio.Common ERROR SolarWinds.Orion.Core.Models.Discovery.TypeResolverProxy - (null) Cannot load type Solarwinds.F5.Common.Models.Discovery.F5DiscoveryPluginResult,Solarwinds.F5.Common
The issue occurs only for a manual import of results. (MONITORING SETTINGS page of Network Sonar Wizard)
Several options exist for workarounds.
- Run automatic discovery on the MONITORING SETTINGS of configuring the discovery.
- Upgrade to Orion platform 2020.2.1 (not 2020.2 where the issue still existed).
- Run the import from the main poller if possible rather than the free poller.
