Disappeared APs on WLC are not removed in the web console immediately
This article discusses the behavior in NPM where Access Points(APs) removed from WLC are not removed in the web console immediately.
Here's an example:
A Cisco WLC shows no access point in the dashboard after removal
List of Thin Access Points resource still shows the access point as Unknown
Solution 1 - Wait
NPM will automatically remove disappeared APs in the next database maintenance if they are more than 7 days old.Solution 2 - Enable RemoveDisappearedAPs
- Go to Advanced Configuration settings
- Search for 'RemoveDisappearedAPs'
- Tick the checkbox to enable it
- Click 'Save' to commit the changes
