Disable the IIS web banner and other IIS headers in the Orion Platform
This article contains some helpful steps on how to harden your IIS Server by disabling the header and banner in IIS 10.0. This avoids the display of minor information leaks in HTTP response headers.
5/14/2019 11:34 AM
1/31/2025 12:55 PM
This article details how to configure the Internet Information Services (IIS) for Windows Server to prevent the display of minor information leaks in HTTP response headers. In some cases, a server banner may display information about the underlying hosting environment.
Some of the information that can be exposed are:
  • Server: The web server version.
  • X-Powered-By: Indicates the website is "Powered by ASP.Net".
  • X-AspNet-Version: Indicates the version of ASP.NET used by the website.
Network Performance Monitor
  • The HTTP Header "X-ASPNET-VERSION" reveals the version of ASP.NET being used by the web.config file.
 Remove the "X-Powered-By" header
  1. Open the IIS Manager.
  2. Select the Orion website.
  3. Select "HTTP Response Headers"
  4. Select the "X-Powered-By" HTTP Header and select "Remove".
  5. Disable the HTTP header "X-POWERED-BY":
    1. Open the web.config file located in the root directory for the Orion website.
    2. Just after the <system.web> tag add:
      <httpRuntime enableVersionHeader="false" />
    3. Save the file.
  6. Restart the Orion Module Engine.
Remove the "X-AspNet-Version" header
  4. Select the "X-AspNet-Version" HTTP header and select "Remove".
  5. Disable the HTTP header "X-ASPNET-VERSION":
    3. Save the file.
Remove the remote Server header
These directions apply to IIS 10.0 only.
  2. Configure requestFiltering in the web.config system.webServer node:
    <security>
    <requestFiltering removeServerHeader ="true" />
    </security>
  3. Save the file.
For additional directions on updating your IIS configuration settings to remove information from the HTTP response headers, see the following article from the Microsoft IIS Support Blog:
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
