Applications Systems
Modify / Disable the HTTPS Bindings Monitor in AppInsight for IIS
This article provides steps on how you can modify or disable the https binding monitor in AppInsight for IIS.
- On the AppInsight for IIS monitor > Click into one of your websites which are affected
- In the top right corner click edit Thresholds
- Click the + sign for the HTTPS / HTTP Bindings component monitor.
- Click the Override Template button to the right of the respective setting to modify, such as Credentials or Port
- Alternatively, disable the Bindings Monitor for the site in question by Overriding the 'Enable Component' setting, and set it to 'Disabled'.
