Tools
Disable paging on a Cisco Small Business device
This article describes how to disable paging on a Cisco Small Business device in Kiwi CatTools.
10/9/2018 7:06 PM
10/9/2018 7:06 PM
Kiwi CatTools
  1. On the Devices pane of your application, select the device and click Edit.
  2. On the Variations tab, click Use Variations.
  3. On the Additional Commands tab, select the Disable Paging field and enter terminal datadump.
  4. Click Save. Paging should now be disabled.
