Applications Systems
Disable monitoring for components of AppInsight applications (SAM)
This article describes how to determine if a component can be disabled and how to disable these components in AppInsight for SQL, AppInsight for Exhange and AppInsight for IIS.
11/29/2018 10:29 PM
4/9/2025 8:31 PM
This article describes how to disable the monitoring of a component in AppInsight for SQL, AppInsight for Exchange, and AppInsight for IIS in SolarWinds SAM by editing the related application monitor.
Note the following details about disabling monitoring for components:
  • Depending on how SAM is configured in your environment, you may require SAM Administrator rights to disable component monitoring. See: You must be a SAM Administrator to access the page.
  • Only a selected subset of components can be disabled for AppInsight applications. This includes the following types.
    • Windows Process Monitors
    • Windows Service Monitors
    • Windows Performance Counters
Server Application Monitor
Disabling Components
  1. In the Orion Web Console, click My Dashboards > Applications > SAM Summary.
  2. In the All Applications resource on the Application Summary page, expand an AppInsight application to display instances of the application on nodes.
  3. Click a Microsoft Exchange instance to open its summary page. The Application Details resource/widget displays components currently being monitored. (If the Application Details resource does not appear, you can add it to the page).
  4. Click Edit Application Monitor.
  5. In the list of Component Monitors, expand the details for the component as shown in the screenshot below.
  6. Next to the Enable Component option, click Override Template.
  7. Select Disabled in the Enable Component field.
  8. Collapse the component details and click Submit at the bottom of the page.
It is important to note AppInsight Applications cannot be customized in the same way as traditional application templates is that unlike templates with individual component monitors, AppInsight applications have been ground-up purpose-built to be as efficient as possible. This means that in many cases a single query may return a multitude of different information. As such, it's not possible to disable just one or two components when the single query that's responsible for collecting this information is also collecting 10-20 other metrics as well.
As a result, it may not be possible to disable many components within the AppInsight applications
As can be seen, these sample components do not have an option to be disabled.
Option 2:
If the component is unable to be disabled and which is giving false alerts.
The other way will be by removing the threshold. Statistics will still be collected but they will no longer trigger/alert. Simply delete the warning and critical thresholds such that the fields are null.
NOTE: Whatever last polled data would still display even after disabling the component monitor.
