Applications Systems
Disable hardware health monitoring manually
When a target device stops providing hardware health information (for example, after moving from a physical to a virtual environment), there is no option in SAM to disable polling hardware health for this node.
11/29/2018 10:29 PM
12/16/2019 9:25 AM
This article describes how to disable Hardware Health monitoring for a server if, for example, the server moved from a physical to a virtual environment. The Orion Web Console continues to display hardware data for virtual servers as N/A or Undefined in various widgets (formerly called resources), and there is no option in SAM to disable polling hardware health for a node.
Server Application Monitor
Although you cannot disable hardware monitoring for a node in the Orion Web Console, you can do it directly in the database by setting the IsDisabled column to 1 in the APM_HardwareInfo table.
You must have Node Management rights to perform this workaround.
To disable hardware monitoring for a node, use the following SQL script:
UPDATE APM_HardwareInfo SET IsDisabled = 1 WHERE NodeID = InsertNodeIdHere
After you execute the script, the polling job for the node is removed within 30 seconds. When the Orion Web Console refreshes (by default, every five minutes), hardware-related resources and statistics disappear from the Node Details page.
To delete hardware-related health data from the Orion database for a specific note, use the following SQL script:
DECLARE @NodeID int
SET @NodeID = _InsertNodeIdHere_
DELETE FROM APM_HardwareInfo WHERE NodeID = @NodeID
DELETE FROM APM_HardwareCategoryStatus WHERE NodeID = @NodeID
DELETE FROM APM_HardwareItem WHERE NodeID = @NodeID
To delete orphaned historical data for sensors, run this command:
EXEC apm_dbm_APM_HardwareItemStatistics_DeleteOrphans
For reference, see:
