Disable/ enable nodes and agents using SQL
If you have hundreds or thousands of nodes or agents that need to be disabled/ enabled all at once, this article will be helpful.
3/10/2021 6:07 PM
6/10/2022 1:53 AM
SQL can be used for performing bulk tasks that would otherwise be impractical or less convenient in the Orion web console. The manage nodes page can only manage up to 250 nodes at a time, the manage agents can manage up to 1,000 agents at a time.
Using SQL, these limitations are removed.
Orion Platform
Please keep in mind these queries will change ALL agents/ nodes management status.
To manage
This will manage all the agents again:
Update AgentManagement_AgentPlugins
set status = 1 ;
This will manage all the Nodes again:
UPDATE dbo.NodesData
SET Unmanaged = 0 ;
To unmanage
This will unmanage all the agents again:
set status = 0 ;
This will unmanage all the Nodes again:
SET Unmanaged = 1 ;
