Applications Systems
Disable an Unwanted Component Monitor in AppInsight for Active Directory in SAM
This article provides steps to disable a specific component monitor under AppInsight for Active Directory when a monitored event or check is not required in the environment.
This article provides steps to disable a specific component monitor under AppInsight for Active Directory when a monitored event or check is not required in the environment. It explains how to identify the correct application and component entry, update the database record, and validate the change.
Use this procedure when:
You do not want a specific AppInsight for Active Directory component to be monitored
A specific event or check is not applicable in the customer environment
You need to disable only one component monitor without affecting the rest of the Application Monitor
This behavior can occur because AppInsight for Active Directory includes multiple predefined component monitors as part of the application. Some of these component monitors may not be applicable or required in every environment.
Step 1: Identify the application and target component
Run the following query to confirm the component monitor entries for the target application:
SELECT [ID], [ApplicationID], [Name], [IsDisabled]
FROM [dbo].[APM_Component]
WHERE [ApplicationID] = [ApplicationID]
AND (
[Name] LIKE '%[keyword1]%'
OR [Name] LIKE '%[keyword2]%'
Example:
WHERE [ApplicationID] = 2
AND (
[Name] LIKE '%account failed%'
OR [Name] LIKE '%attempted to logon%'
Review the output and confirm the correct component monitor names and IDs before proceeding.
Step 2: Disable the required component monitor
If the component names are confirmed, run the following update:
UPDATE [dbo].[APM_Component]
SET [IsDisabled] = 1
AND (
If you want to target specific rows only, use the component IDs instead:
WHERE [ID] IN ([ComponentID1], [ComponentID2]);
Step 3: Validate the change
Run the same select query again to verify that the component monitor is now disabled:
AND (
Confirm that:
the correct component monitor was updated
the IsDisabled value now shows the disabled state
no unrelated components were changed
