Tools
Disable ServU Web Client for a ServU Domain
This article helps Serv-U administrators to remove the capability of the Serv-U users on a specific Serv-U domain in accessing Serv-U through Serv-U Web Client.
11/15/2018 8:40 AM
11/15/2018 8:40 AM
This article describes how to disable Serv-U Web Client for a specific Serv-U domain.
Not Applicable.
  1. Log into the Serv-U Administrator Console.
  2. Go to the Domain Limits & Settings.
  3. Under Limits tab, go to HTTP Limit Type.
  4. Click the Add button found on the lower part of the screen.
  5. Select the following Limit:   Allow users to use Web Client.
  6. Untick the checkbox for "Allow users to use Web Client".
  7. Click Save.
