Disable Multicast Event Without Disabling Multicast Monitoring in NPM
This article is created to serve as a guide on how to disable multicast event without disabling multicast monitoring in NPM
- Connect to the Orion server.
- Open Database Manager from the Solarwinds Orion folder of the Start menu.
- Select Add Orion server.
- Expand the SQL Server and Orion database in bold.
- Right-click the database and select New Query.
- Paste the following and select Execute query in the window on the right:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. UPDATE EventTypes SET Record=0 WHERE Name='Multicast traffic down'To re-enable the events, change the "Record" value to 1 and execute the query.
