Disable Automatic Index Defragmentation
Disable the automatic index defragmentation on the SQL Server hosting your SolarWinds Platform Database, either using Settings in the SolarWinds Platform Web Console or executing a SQL script on the SQL Server hosting your SolarWinds Database.
10/30/2018 4:28 PM
2/21/2025 11:56 PM
This article describes how you can disable automatic index defragmentation, using Settings in the SolarWinds Platform Web Console, or executing a SQL script on the SQL Server hosting your SolarWinds Database.
Network Performance Monitor
  1. Log in to the SolarWinds Platform Web Console using an administrator account.
  2. Click Settings > All Settings > Polling Settings.
  3. Scroll down to Database Settings, and clear the Index Defragmentation box, then Submit.
    The index defragmentation does not run anymore.
