Device Template for Cisco Firepower nodes for NCM
This article provides the information to create a Device Template for Cisco Firepower and may be necessary when you are unable to download a running configuration from Cisco Firepower.
3/11/2020 7:58 AM
4/25/2023 6:37 PM
When you are unable to obtain running-config from Cisco Firepower running 6.4.0.4, you may need to create a Device Template specifically for Cisco Firepower.
If you have any questions regarding this please open a support case with the NCM team so that we can assist you.
Network Configuration Manager
Download never completes, sometimes gets discarded due to connectivity issues. Required to run NCM compliance reports on configuration of Firepower appliance
Create Device Template using the commands below:
<Configuration-Management Device="Cisco Devices" SystemOID="1.3.6.1.4.1.9.1.2404" AutoDetectType="BySystemOid">
 <Commands>
   <Command Name="EnableCommand" Value="system support diagnostic-cli${CRLF}enable" />
   <Command Name="RESET" Value="" />
   <Command Name="MenuBased" Value="false"/>
   <Command Name="UseVirtualPromptForCommands" Value="true"/>
   <Command Name="Startup" Value="startup-config" />
   <Command Name="Running" Value="running-config" />
   <Command Name="DownloadConfig" Value="show ${ConfigType}"/>
   <Command Name="Version" Value="show version" />
   </Commands>
</Configuration-Management>
If the configs need to show the passwords in clear text, the template below can be used instead:
 <Commands>
   <Command Name="Running" Value="more system:running-config" />
   </Commands>
There are instances that you need to update the "Enable Command" as listed below
<Configuration-Management Device="Cisco Firepower" SystemOID="1.3.6.1.4.1.9.1.2404" AutoDetectType="BySystemOid" SystemDescriptionRegex="">
 <Commands>
   <Command Name="EnableCommand" Value="system support diagnostic-cli${CRLF}enable${CRLF}${CRLF}" />
   <Command Name="RESET" Value="terminal pager 0" />
   <Command Name="MenuBased" Value="false" />
   <Command Name="UseVirtualPromptForCommands" Value="true" />
   <Command Name="DownloadConfig" Value="show ${ConfigType}" />
   </Commands></Configuration-Management>
