Determine the NTA flows per second
This article describes how to determine the NTA flows per second that are received by the NTA collector.
- Log in to the Orion server, and then open Windows Performance Monitor (© 2019 Microsoft, available at https://docs.microsoft.com/, obtained on January 22, 2019) on the server.
- Click the green + button to add a counter.
(Screenshot property of © 2017 Microsoft)
- Scroll down and click SolarWinds NetFow to expand.
- Find Netflow .. Flows received per second. Select all the flow types that apply to your environment, and then click Add to display the selected counter on the graph.
- Select the graphing option, and then select Report.
This should give you a real-time count of the received NetFlow packets.
