Tools
Detach clients from AD/LDAP connections
This article describes how to detach Client accounts from an AD / LDAP account so you can change their passwords.
Environment
- WHD 12.x
- Windows 2008 Server
Steps
- Click Setup > Clients > AD / LDAP connections.
- Click a connection in the Connection column.
- Click the pencil icon to enter Edit mode.
Before you delete the connection, a warning displays:
If you shift+click Delete button, then clients will be deleted". If you just click Delete button with left mouse button, then the clients will be detached from connection and will stay in WHD." - Click Delete and confirm your selection.
If you shift+click Delete button, the clients are deleted. If you click Delete, the clients are detached from the connection and remain in Web Help Desk.
You can now set the Web Help Desk instead of using LDAP authentication
