Security Compliance
Deploy the latest HP System Management Homepage using Patch Manager
This article describes how to deploy the latest Hewlett Packard System Management Homepage using Patch Manager.
10/26/2018 8:56 PM
10/26/2018 8:56 PM
When you deploy the latest Hewlett Packard (HP) System Management homepage with Patch Manager, you discover that the latest Hewlett Packard Proliant Servers Package is over two years old. If you modify the 7.1.1.1 package for the new version, the update fails and returns a "Not Applicable" message on most servers.
Patch Manager
The Hewlett Packard Server Updates Catalog stopped receiving updates in mid-2012.
The catalog content is provided by HP and SolarWinds has no control or involvement in the content included with the catalog. Contact HP for information regarding the newer version of ProLiant Server packages for the HP Server catalog.
Workaround
To add the latest Service Pack for ProLiant (SPP) catalog in Patch Manager:
  1. Log in to Patch Manager as an administrator.
  2. In the navigation pane, expand Administration and Reporting and select Software Publishing.
  3. Click Synchronization Settings .
  4. In the Third Party Updates Options window, click the Other Catalogs tab.
  5. Add the catalog.
    1. Click Add Catalog.
    2. In the Catalog Path field, type:
      https://downloads.hpe.com/pub/softlib/puc/hppuc.cab
    3. In the Publisher field, enter Hewlett Packard.
    4. In the Name field, type HP ProLiant Update Packs
  6. Click OK.
  7. In the Actions pane, click Synchronize Now.
    Patch Manager synchronizes the latest Service Pack for ProLiant (SPP) catalog, which should contain the latest HP System Management Homepage and the latest drivers and firmware.
To learn more about this issue, see Service Pack for ProLiant (SPP). (© 2018 Hewlett Packard Enterprise Development LP, available at https://www.hpe.com, obtained on March 29, 2018)
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
