Delete ESX Ghost Entry
How to delete ESX Ghost Entry from the SolarWinds Database.
Using Database Manager
- On your Windows Server, search for Database Manager and then click Add Default Server.
- Right click on your SolarWindsOrion database > select New Query.
- Use the following query to VIEW Duplicate or Ghost ESX Entry:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. Select HostName, HostID, NodeID, DataCenterID, ClusterID, ManagedObjectID From [dbo].[VIM_Hosts]
Where HostName = 'Put The Host Name Here' - Use the following query to DELETE Duplicate or Ghost ESX Entry:
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. Delete HostName, HostID, NodeID, DataCenterID, ClusterID, ManagedObjectID From [dbo].[VIM_Hosts]
Using SQL Server Management Studio
- On your Windows Server, search and login to your SQL Server Management Studio.
- Expand Databases > right click on your SolarWindsOrion database > select New Query.
