Default ping settings for NPM
This article describes the default ping settings for NPM.
By default, NPM ICMP settings is set to 120 seconds.
Default Node Poll Interval:
Check response time and status every configured time interval.
ICMP Timeout:
All ICMP (ping) requests made by the SolarWinds poller time out if a response is not received within the period designated. By default, this period is 2500 ms.
ICMP Data:
This string is included within all ICMP packets sent by SolarWinds. The default size is 23 bytes.. Please be aware that the default PING size for a command prompt PING is 32 bytes. You can add 9 characters to the default data set in this setting to increase the ICMP packet size to 32 bytes.
Note:
- To increase the packet size open the web console and navigate to Settings -> All Settings.
- In the Thresholds and Polling group click on Polling Settings.
- In the Network section edit the ICMP Data field then scroll to the bottom of the page and click submit.
