Deactivate and activate Orion product licenses during migration
This article provides steps to deactivate and active Orion products during migration from the original server to the new one.
It applies to all versions of Orion products using up to NPM 12.0 (Core 2016.1). After NPM 12.1 (Core 2017.1), the License Manager functionality was moved to the web.
Note: The user will have 30 days to activate the license on the new server.
- Go to Start > SolarWinds > License Manager (Guide to SolarWinds Product Licenses )
- Deactivate all licenses.
- Perform the migration.
- Upon completion of the migration, go to Start > SolarWinds > License Manager.
- Activate all licenses
If the Orion server is no longer accessible, the user will need to log a separate case to SolarWinds Customer Service to manually deactivate the license/s.
