Tools
Deactivate or transfer the Serv-U license key
This article describes how to deactivate or transfer the Serv-U license key
10/14/2018 8:30 PM
4/5/2019 1:23 PM
Unlike other SolarWInds products, Serv-U does not use License Manager.
To use the Serv-U license key on another machine, you should deactivate the existing server first, then register the key to another Serv-U instance.
Serv-U MFT
  • Log in to the Serv-U MFT server as an administrator
  • Locate the Serv-UID.txt file in C:\ProgramData\RhinoSoft\Serv-U (Folder is Hidden in Windows by default)
  • Rename or move the file to another location
  • Restart the Serv-U MFT service
Serv-U Gateway
  • Log in to the Serv-U Gateway server as an administrator
  • Locate the Serv-U-Gateway-ID.txt file in C:\ProgramData\RhinoSoft\Serv-U Gateway (Folder is Hidden in Windows by default)
