Database defragmentation option not enabled in Orion NPM by default
This article discusses why the database defragmentation option is not enabled by default in NPM. Also, it discusses the impact on having database defragmentation enabled.
This article describes why the database defragmentation option is not enabled by default in NPM. Also, it describes the impact on having database defragmentation enabled.
This article is also part of Quick Orion database health check guide (© 2003-2018 SolarWinds Worldwide, available at https://support.solarwinds.com, obtained on Dec 17, 2018).
The DB fragmentation is normally performed by the SQL DBA by running DB Maintenance Tasks on a regular basis. This option is disabled by default in order to avoid duplicate tasks.
There are several tasks that should be performed on a regular basis. One of these tasks is to manage database fragmentation. Depending on the tables, queries, and indexes that are being used, fragmentation can cause performance issues, as well as using unnecessary space in the database.
