Database Maintenance fails due to ANSI_WARNINGS setting in dbm_AggregateTimeSerie_part in Solarwinds Self-Hosted Platform
This article discusses an issue where database maintenance can fail during the Finalize Maintenance phase because the stored procedure dbm_AggregateTimeSerie_part sets ANSI_WARNINGS OFF, which SQL Server rejects for operations involving indexed views/constraints. This causes repeated failures for multiple summary tables and incomplete historical data.
5/4/2026 2:00 PM
5/4/2026 3:40 PM
When running Database Maintenance, the Finalize Maintenance phase may fail for multiple time-series summary tables. The Database Maintenance log shows an error about incorrect SET options and ANSI_WARNINGS, and the job reports repeated failures for several operations.
From swdebugmaintenance.log
Detected that operation [Finalize Maintenance]-[CPULoad] failed 3 times in a row.
Detected that operation [Finalize Maintenance]-[CPUMultiLoad] failed 3 times in a row.
Detected that operation [Finalize Maintenance]-[InterfaceAvailability] failed 3 times in a row.
[Failure] 0.44s Finalize Maintenance - CPULoad
Message:
dbm_ExecuteMaintenance: dbm_AggregateData_part: dbm_AggregateTimeSerie_part:
XACT_STATE=-1
SELECT failed because the following SET options have incorrect settings: 'ANSI_WARNINGS'.
Verify that SET options are correct for use with indexed views and/or indexes
on computed columns and/or filtered indexes and/or query notifications and/or
XML data type methods and/or spatial index operations.,
ALTER TABLE CPULoad_CS_Hourly_stg WITH CHECK ADD CONSTRAINT CHK_CPULoad_CS_Hourly_stg
CHECK ([Timestamp] >= '20260310' AND [Timestamp] < '20260311')
Network Performance Monitor
In affected versions, the stored procedure dbm_AggregateTimeSerie_part explicitly sets:
SET ANSI_WARNINGS OFF
During Database Maintenance, this procedure is used when finalizing data into staging and summary tables that may involve:
  • Indexed views
  • Constraints
  • Computed columns or filtered indexes
which require specific SET options (including ANSI_WARNINGS ON) to be enabled at execution time.
If the session executing the procedure does not meet these SET option requirements, SQL Server rejects the query and raises the error:
As a result, the Finalize Maintenance step fails for multiple objects, and the job reports repeated failures.
Resolution:
This issue is addressed in SolarWinds Self-Hosted Platform 2026.1 and later. Consider upgrading your environment. If you can't upgrade, use the workaround below.
Workaround:
Important: This workaround involves editing a stored procedure in the SolarWinds Platform database.
  • Ensure you have a full backup of the SolarWinds Platform database.
  • In SSMS, expand:
    • Databases → (your SolarWinds Platform DB) → Programmability → Stored Procedures
  • Locate the stored procedure:
    • dbm_AggregateTimeSerie_part
  • Right-click it and choose:
    • Script Stored Procedure as → ALTER To → New Query Editor Window
  • Remove the ANSI_WARNINGS setting
    • In the script that opens, locate the line:
    • Remove line and press F5 or Execute button to change the source code.
  • Run Database maintenance manually or wait until its standard scheduled time.
