Data retention for NetPath
How to change the retention period for NetPath data in the SolarWinds SQL Server database.
10/29/2018 6:50 PM
3/5/2026 4:49 PM
SolarWinds uses SQL Server to collect data from network paths while probing. The database also contains configuration information for services and probes that collect the information.
By default, SolarWinds retains NetPath data for 30 days.
Network Performance Monitor
The amount of data collected and stored by NetPath can add significant storage pressure on SQL Server. You should select an appropriate retention period and probing intervals related to the size of your database storage. See NetPath requirements for more information.
Edit the retention period
You cannot change the retention period through the SolarWinds web interface. To edit this setting, modify the value in the dbo.Settings table in the SQL Server database.
SETTINGSIDDESCRIPTION
NetPath-Settings-Retain NetPath DetailThe number of days data is retained in the database for the Performances, Tests, and Traces data. Care should be taken when increasing this value as it will add additional storage constraints on the database. The default value is 30 days.
Note: The above setting is specific to retention only for NTA.  This setting does not apply to other modules.
