Tools
Dameware error: The remote system is not currently at the Logon Desktop
This article addresses the following Dameware error: The remote system is not currently at the Logon Desktop. Your credentials do not allow for access at the current desktop state.
This article addresses the following error:
This error occurs when the Dameware user does not have administrator rights within the operating system security on the remote machine and the Permission Required for these Account Types setting is disabled.
Non-administrators will always require explicit permissions from the desktop user before they can connect, but if the Permission Required for these Account Types setting is disabled, any non-administrator user will be denied access to the machine without prompting the desktop user to accept the connection.
- Check to see if the Windows user account is a member of the administrator group.
- If the user is not an administrator, see Modify Dameware client agent permissions to enable or prevent non-administrator access.
