Tools
Dameware Remote Support (DRS) blank display when viewing system properties
This article describes the blank displays when viewing the Windows System properties in Dameware Remote Support / DRS.
- Account running DRS application has no right to access the Windows System properties
- Disabled required Windows services on the target machine.
- Make sure that the following services are running on the target machine
- Remote Registry
- Windows event collector
- Windows Management Instrumentation
- Remote Event Log Management
- Remote Service Management
- Ensure the host and remote machines are on the same domain or have a trust relationship.
- Check to make sure you are running Dameware Remote Support with an admin account.
- If the issue is Event Viewer of the remote machine is not accessible. ensure that the following steps can be performed on the DRS Server:
- Open your Windows Event Viewer.
- From the Action Tab, click “Connect to another Computer”.
- Select “Another Computer:” and input the IP address of the target machine.
- Check “Connect as another user:”.
- Click “Set User” and input your user account (DOMAIN\Username) and password (for local account, Hostname or IP\Username).
- Click OK.
- If there is an error message, then it is not possible in the Windows level to do this, so Dameware will not be able to do this as well.
